Wireframe options
Command
Path
View bar
Wireframe Options
View > Rendering
A wireframe render uses lines to represent the edges of objects. Planar objects with solid fills are drawn in stacking order. In a 3D wireframe view, objects may overlap, obscuring objects lower in the stacking order. The wireframe options control whether fills should be visible for planar objects in 3D views, and if they are visible, sets the fill opacity of filled planar objects.
To set wireframe options:
Select the command.
Alternatively, if a different render mode is active, select the command under Options For Other Render Modes in the Current Render Mode menu on the View bar.
The Wireframe Options dialog box opens; set the parameters.
Parameter
Description
Show fills in planar objects in 3D views
Displays fills for 2D planar objects in 3D views
Fill opacity
Sets the opacity of filled 2D planar objects for situations where objects overlap
Rendering modes
